Has any one writtena DLL library to
perform the broadcast successfully ?
>From: Mark Ahrens <marka@m2476dmc.nsr.hp.com>
>Subject: Re: VRf: Need help
>To: hpvxd_xc@hpislsup.lvld.hp.com
>Date: Wed, 30 Jul 97 18:07:45 MDT
>X-Hpvue$Revision: 1.8 $
>X-Vue-Mime-Level: 4
>Mailer: Elm [revision: 70.85]
>Content-Length: 2142
>Just a clarification, not only are broadcast *addresses* not supported, but
>neither are UDP messages, which tend to be broadcast-like in the sense that
>they are connectionless.
>Mark Ahrens
>Hewlett Packard
>US TMO Call Center
>>I asked this same question several months ago and was told by the lab
that VEE
>>does not support broadcast messages. You may need to write a DLL library
to
>>perform the broadcast.
>>If you get a better answer or find a method that works, please let the
reflector
>>know about it.
>>Good luck!
>>Bruce Wenner
>>HP St. Paul
>>______________________________ Reply Separator
_________________________________
>>Subject: VRf: Need help
>>Author: Non-HP-ndogra (ndogra@mail.arc.nasa.gov) at HP-USA/o2=mimegw3
>>Date: 7/30/97 4:38 AM
>>Hi everyone there in the world of mystery!
>>Subject: UDP PROTOCOL
>>I am a new kid on the block (of HP VEE).
>>I have HPVEE 4.0 installed in Windows95 based PC. I have a requirement to
>>transmit data (broadcast) to a UNIX based remote host on the network, in
a "send
>>& pray" mode.
>>I am using I/O-->To/From Socket addressing under HP VEE.
>>There will be no request from the remote host on the network for data. There
>>will be no acknowledgement from the host of the data received. I just keep
>>pumping out data. I don't even care if transmission media (Ethernet card
and/or
>>fibre optic cable in this case) is lost.
>>I think "User Datagram Protocol (UDP)" is the right way to go for this
>>application. However, I have not been able to determine either from HP VEE
>>documentation or Windows95 documentation, the methodology to configure in
UDP.
>>I have no problem configuring network based on TCP/IP. I believe UDP is a
subset
>>of TCP/IP.
>>I'll appreciate if some one shed light on the use of UDP in the environment
>>described above.
>>Thanks in advance
>>Sincerely
>>Narinder Dogra
>>Narinder Dogra
>>Tel: (415) 604-2176
>>Building 213, 2nd floor, cubicle 5
>>M/S 213-15
>>Moffett Field, Ca 94035-1000
>Mark Ahrens
>Hewlett Packard T&M AEO Email: mark_ahrens@hp.com
>(800)-452-4844
>"Ask me about Custom Test Solutions"
Narinder Dogra
Tel: (650) 604-2176
SVERDRUP TECHNOLOGY
NASA/AMES Research Center
M/S 213-15
>X-Vue-Mime-Level: 4
>Mark Ahrens
>Hewlett Packard
>US TMO Call Center
that VEE
to
reflector
>>know about it.
>>Good luck!
>>Bruce Wenner
>>HP St. Paul
a "send
>>& pray" mode.
and/or
UDP.
subset
>>of TCP/IP.
>>described above.
>>Thanks in advance
>>Sincerely
>>Narinder Dogra
>>Narinder Dogra
>>Tel: (415) 604-2176
>>M/S 213-15
>Mark Ahrens
>(800)-452-4844
Narinder Dogra
Tel: (650) 604-2176
SVERDRUP TECHNOLOGY
M/S 213-15
Subject: <bold>UDP PROTOCOL
</bold>I am a new kid on the block (of HP VEE).
a "send & pray" mode.
There will be no acknowledgement from the host of the data received. I
just keep pumping out data. I don't even care if transmission media
(Ethernet card and/or fibre optic cable in this case) is lost.
VEE documentation or Windows95 documentation, the methodology to
configure in UDP.
subset of TCP/IP.
environment described above.
Thanks in advance
Sincerely
Narinder Dogra
Narinder Dogra
Tel: (415) 604-2176
M/S 213-15
