> > Subject: Vrf: how to print entire userpanel?
Try to explain better.
my main panel looks something like:
|button|| |
|button|| some X-Y display |
+------+| at least two |
|button|| different functions |
+------+| can give a pop-up |
|button|| panel, and the |
+------+| main program has |
| || the default panel |
| some || |
|status|| |
Most parts of the screen are filled by the main program, and can be
'overruled' by different pop-up-panels.
printing the X-Y displays is simple.
printind the status info is also simple
But we need all together on one sheet:
the status AND the X-Y display AND the actual buttons (just in fact a
screen print at the main level).
It is possible when I manually run my program, via the menu
File/Print Screen.
However, when I start from the commandline HPVEE -r <myfile.vee>,
(which will be the final situation) there is no menu (what I expect
indeed).
I would need to add a button 'PRINT' which would do the job, but from
here I only can print 'lower' panels seperately.
I see no way to add a button which can print the entire main
userpanel, including the active pop-ups.
Groetjes, Johannes
|button|| |
| || the default panel |
| some || |
|status|| |
File/Print Screen.
indeed).
Groetjes, Johannes
