Howdy
Here's a seemingly simple item that has me stumped. What I am
doing is to attempt to access my libraries of VEE functions- existing
on my Unix system- from my PC. I have NFS mounted the Unix file system
and created a symbolic link ( shortcut on the PC running WIN95 )
to my library directory. No problem.
DOS can't deal with any of this, which is no surprise, but no big loss.
(DOS complains about invalid directories when I attempt to cd to them).
Yet, I have no problem navigating to the libraries from
Explorer. Similarly I have no trouble with the "merge" or "open file"
or "save" from within VEE4.01. So it would seem that VEE is making
the correct 32 bit API calls.
However, when I try to merge the files from the VEE menu system
then I get an error that says that the file can't be found, even though
the indicated path is exactly correct and findable via Explorer.
And, when I link the menu file from my unix directory into the
VEE install directory on my PC, then vee doesn't recognize the menu file.
Yet when I copy the exact same file from the unix system into
the local PC directory then the menu file is recognized and incorporated
as is usual.
Seems strange that a "merge" works but teh menu doesn't , given that
all the menu pick does is a "merge" operation.
Has anyone gotten something like this to work?
Any hints?
thanks!
Stan Bischof
stanb@sr.hp.com
Stan Bischof Hewlett Packard Company 707-577-3994 stanb@sr.hp.com
Subject: Re: VRF: How to access NFS mounted files via VEE menu system?
To: hpvxd_xc@hpislsup.lvld.hp.com, Stan Bischof <stanb@hpnmrsb2.sr.hp.com>
--- On Tue, 24 Jun 1997 15:29:27 -0700 (PDT) Stan Bischof <stanb@hpnmrsb2.sr.hp.com> wrote:
> Howdy
> as is usual.
> Any hints?
> thanks!
> Stan Bischof
> stanb@sr.hp.com
---------------End of Original Message-----------------
Stan,
It all works fine here. I am running Windows NT 4.0 not 95 which may be the difference. It could also be
something funny with your NFS software on the PC. I am running Netmanage Chameleon.
Name: Tom Sanders, Symtx (formerly Symmetrix)
Date: 06/24/97 Time: 15:42:09
as is usual.
Any hints?
thanks!
Stan Bischof
stanb@sr.hp.com
> Howdy
> as is usual.
> Any hints?
> thanks!
> Stan Bischof
> stanb@sr.hp.com
Stan,
