I've never tried Vee with HP-UX, but isn't there a no hangup function that
would pass the process onto the super process when you logout like the nohup
command?
Greg Goebel wrote:
> send q VRF-Logging_Out_VEE vrf
> from: Greg Goebel / HP-MXD
> gvg@lvld.hp.com / 800-452-4844
> website: ftp://fcext3.external.hp.com/dist/mxd/index.html
> to: VRF
> date: Wednesday, 25 March 1998 1013 MST
> Hi All:
> On this business of logging out and leaving VEE running: the only way you
> could do this is on HP-UX, and then only if you have VEE operating over
> X-Windows with a console on a remote machine. VEE *must* have a display to
> write to.
> As far as remote consoles on PCs go, I believe there are some technology
> options available or becoming available, but how VEE would work with them
> is neither known nor guaranteed. An item to work for in the future.
> [<>] regards -- gvg
command?
> to: VRF
> Hi All:
> write to.
> [<>] regards -- gvg
to: VRF
Hi All:
write to.
[<>] regards -- gvg
