Greg,
Create a shortcut for the runtime executable (i.e. C:Program
FilesHewlett-PackardVEE 4.0 RunTimeveerun.exe). From the shortcut's
Properties dialog box, click on the Shortcut tab and modify the Target
to something like this (and use the quotes):
"C:Program FilesHewlett-PackardVEE 4.0 RunTimeveerun.exe"
-geometry250x250+0+0 "C:My DocumentsVEE ProgramsYour Program Name"
Run your program from the shortcut.
John
Greg Noseworthy wrote:
> I'm running HP VEE 4.01 on NT Work Station V4.0
> The problem I'm having is that I can't figure out how to set the
> starting window size when I use Runtime VEE... The window allways
> starts quite small.
> According to the help menu, there's a command line variable
> (geometry) but it can only be used with VEE, not the Runtime.
> _
> / Greg.Noseworthy@comdev.ca
> / __ ComDev
> / / _ -----------------------------
> (_/_/___) Space Group
John
> starts quite small.
> _
> / __ ComDev
Oh, and another thing ... make sure you get the 4.01 patch. Geometry was
broken for RunOnly in 4.0.
Regards -- gvg
> Greg,
> John
> > starts quite small.
> > _
> > / __ ComDev
