Bug VXDaa27273 vee Submitted 990312
DUPLICATE of VXDaa24249 Assigned 990314
5.01
Duplicate 990314
"add control pin to REGRESSION object"
LABORATORY INFORMATION
Assigned engineer: susanw
Detection method: in-house normal use
Platform: all
Severity: 5
Frequency: 3
Consequences: 2
Workaround: 0
SUBMITTER INFORMATION
Submitter: Stan Bischof
Organization: HP MID
Address: rsb@sr.hp.com
************ Problem (Added 990312 by http) ***********
The regression object is very useful but must be configured manually
using the GUI.
It would be very useful when fitting largely unknown data to be
able to programatically try several different fits.
A control pin allowing input of regression type and parameters
would be great. Then a simple program could try various fits
and examine the "goodness" to see which is best.
There is no reasonable workaround at present.
Stan Bischof
rsb@sr.hp.com
************ History ************
batchbug 990312 100029 Frequency submitted as 3 by Stan Bischof
batchbug 990312 100029 Consequences submitted as 2 by Stan Bischof
batchbug 990312 100029 Workaround submitted as 0 by Stan Bischof
batchbug 990312 100029 Submitted to vee - by Stan Bischof, from the Web.
xddts 990314 164801 N -> A (Assigned to susanw) by susanw
xddts 990314 164813 A -> D (VXDaa24249) by susanw
++++++++++++ Field change log (added to mail by bugmail) ++++++++++++
Changed Timestamp from '2' to '3'
Changed Transition-stamp from '921258031' to '921455293'
Changed Last-mod from '990312' to '990314'
Changed Status from 'N' to 'D'
Changed Updated-by from 'rsb' to 'susanw'
Added Engineer as 'susanw'
Added Engineer-domain as 'lvld.hp.com'
Added Engineer-mail as 'susanw'
Added Assigned-on as '990314'
Added Duplicate-of as 'VXDaa24249'
Added Duplicate-on as '990314'
Added When-found as ''
Added When-caused as ''
Added Prototype as ''
Added Submitter-host as ''
5.01
Duplicate 990314
Platform: all
Severity: 5
Frequency: 3
Consequences: 2
Workaround: 0
using the GUI.
Stan Bischof
rsb@sr.hp.com
