Hi all,
I ran into the following problem with interfacing DLL's, I think I miss just one clue:
I'm using VEE4.01 under NT4
I used DLL's (other, selfmade) before, with success.
I am not a real programmer, but we have a software department which can give me some advice, although they are unfamiliar with VEE.
We have a DLL library (32 bits) to interface with a running application, which controls our microscopes.
Visual basic can interface with this library, and it is tested thoroughly.
My definition file:
/* definition file for XLIB32*/
long Connect(void); /* connect to application */
long IsConnected(void); /* check connection, returns either 1 or 0 */
long Disconnect(void); /*disconnect from application */
long GetOnOff(short *v); /* check status, either 1 or 0 */
long SetOnOff(short v); /* set status, either 1 or 0 */
All functions will return 0 or an errorcode.
Although I'm not sure about the real flow inside these functions, the Connect, IsConnected and Disconnect functions return the values I expect. So it seems VEE can connect to the other application.
But no matter what I do, I get garbage from the GetOnOff and SetOnOff.
I get no errormessage.
Please help!
Any help or hint will be appreciated.
Regards, Johannes Mulder
Philips Electron Optics B.V.
Building AAE-k21
POB. 218, 5600MD EINDHOVEN, NL
+31-04-2766867 (fax: ...66820)
My definition file:
Please help!
Building AAE-k21
