I'm Stuck
Question asked by VRFuser on Apr 22, 1998
Robert,
        When I need to do this I take the name and add "Rec." before it in
     a formula box.  then feed the resulting string into a SET FIELD box
     through a LEFT FORMULA control pin.  I know this works in v3.2, but
     I'm sure it will still work in v4.
     Hope that gives you an idea to work with!
     Thomas Groleau
     Tucson, Arizona
______________________________ Reply Separator _________________________________
Subject: I'm Stuck
Author:  Robert Beckmann <rbeckmann@mindspring.com> (Xspam) at CCGATE
Date:    4/22/98 10:56 AM
>Date: Wed, 22 Apr 1998 13:24:54 -0400
>From: Robert Beckmann <rbeckmann(Xspam)@mindspring.com>
>Subject: I'm Stuck
>I am stuck.  I am trying to access a record in a formula, is it possible
to replace the field name with a variable?  If so what is the syntax?
>Rec.XXX = A    XXX variable name on input pin.
>Any help would be great!
>Robert Beckmann
>Beckmann Technologies, Inc.
>3333 Industrial Drive
>Durham, NC 27704
Please remove <antispam> stuff from return address.
