Dear Vee Exchange,
Here is an excerpt from a bug-resolution that I had just recieved. I
feel the work around is unsatisfactory. What are your opinions? I
submit bugs and enhancement requests often, so should you all.
This is a bad work-around. There shouldn't have to be a work-around.
The fix should be in the control, not in the code I have to write.
The control does not work, in my opinion, as it is supposed to. The
drop-down and pop-up lists should ALWAYS have a timeout feature.
Ciao,
Andrew
______________________________ Reply Separator _________________________________
Subject: vee defect VXDaa17570 was moved to state R by dougk
Author: ddts-at-lvld (ddts@hplvl212.lvld.hp.com) at HP-PaloAlto,shargw6
Date: 3/4/98 10:11 AM
Bug VXDaa17570 vee Submitted 971030
RESOLVED defect Assigned 971106
4.0 Opened 980304
Resolved 980304
"Drop-Down List is modal, could it have a timeout?"
Detection method: in-house normal use
Platform: all
Severity: 5
Frequency: 3
Consequences: 2
Workaround: 0 RESOLUTION INFORMATION
Resolution: no fix
Module[s]:
Fix time (hrs): 0
SUBMITTER INFORMATION
Submitter: andrew hamilton
Organization: HP MXD
Address: andrew_hamilton@hp.com
************ Problem (Added 971030 by http) ***********
The drop-down list of a drop-down-list-box behaves modally, but it has no
time-out feature. Could the drop-down list box have a timeout feature?
ie...It is possible for a user to activate the drop-down list box, but not make
a
selection, therefore hanging up my program. The only other selection control
that has this limitation is the pop-up listbox.
Perhaps the philosophy could be that no selection controls will be modal: unless
they have a timeout feature.
Of course, then the user has to process the timeout.
************ Workaround (Added 980304 by -----) ***********
You can effectively get this behavior by building it into your program.
Take a look at Solitaire.vee and the Options dialog box. You simply
need to keep track of values and then add 'Exit UserObject' objects to
the context.
Ciao,
Andrew
4.0 Opened 980304
Resolved 980304
Platform: all
Severity: 5
Frequency: 3
Consequences: 2
Resolution: no fix
Module[s]:
Fix time (hrs): 0
a
the context.
