> Bonjour !
> I guess that you need also to copy the Vee 4.01 patch file ?
And to run it, and then to run Patchw32.dll as well
Very inconveiniant, and easy to forget!!
With kind regards,
Johannes Mulder
Philips Electron Optics tel +31 40 2766867
Building AAE-room 21 fax +31 40 2766820
P.O.B. 218
5600 MD ACHT, the Netherlands
With kind regards,
Johannes Mulder
P.O.B. 218
> How do I distribute the runtime version of VEE 4.0?I need to be able
> to send a program written in VEE 4.0, along with the runtime portion
> of VEE on floppies to different sites.What files do I need to include?
> Where do they go? etc.....
Sir:
If you look on the CD-ROM, you will find a subdirectory named "runtime".
In this subdirectory, there are other subdirectories named "disk1"
through "disk4".
These subdirectories can be copied to floppy disks and distributed with
your application.
There is a "setup" program in "disk1" that allows the users to install
the bits.
Simple if you know how ...
[<>] regards -- gvg
>Date: Tue, 10 Mar 1998 17:12:57 -0700
>From: Greg Goebel <gvg@lvld.hp.com>
>To: JEFFREY M BLANK <JEFFBLANK@prodigy.net>
>Cc: hpvxd_xc@hpislsup.lvld.hp.com
>Subject: Re: Vrf - Distribution of Runtime
include?
>Sir:
"runtime".
>through "disk4".
>your application.
>the bits.
>[<>] regards -- gvg
______________________________________________________
Get Your Private, Free Email at http://www.hotmail.com
