Hi ALL !
I have completed the installation of the NI Software & NI PCI-6031E
board.
I have tried the NI-DAQ Test Panels included with the NI software, it
works fine, but when running a simple ".vee" on HP VEE, the following
error message displayed:
> "File 'gpib-32.dll' was not found
> > Could not find National shared library file
> > See the VEE installation instructions for details "
Thank you for help.
Adam
> From: Schoth, Ulrik[SMTP:Schoth@KROHNE.MHS.compuserve.com]
> Sent: Tuesday, November 04, 1997 8:38 AM
> To: Nguyen, Adam D
> Cc: HP VEE email reflector
> Subject: AW: National Instruments PCI-6031E board
> Am Dienstag, 4. November 1997 09:47 schrieb "Nguyen, Adam D":
> > I just got a National Instruments PCI-6031E board; this is Plug and
> Play
> > board. I want to use it with VEE 4.01, Windows95.
> > I have tried to configure it with bus address 1405 in the Instrument
> > Manager.
> > When running a simple .vee program, I got the error message:
> Hi Adam,
> you've installed National Instruments' driver software,
> haven't you? If the board is PnP you should have been asked
> by Windows to install it...
> I have an AT-GPIB/TNT card (which is about two years old and not PnP)
> and I had to install it's driver software in two steps:
> 1) I installed the software which I got from NI's WWW server. It's
> called
> "NI-488.2M Software for Windows 95", the current version is 1.2 (it
> includes several GPIB DLL files).
> 2) In system control I selected "add hardware" and added the driver
> for
> the
> AT-GPIB/TNT.
> After that I was able to use it with HP VEE.
> Hope this helps.
> Bye,
> Ulrik Schoth
> Dipl.-Ing. Ulrik Schoth
> Project manager R&D
> Krohne Messtechnik, Ludwig-Krohne-Strasse 5, 47008 Duisburg, Germany
> schoth@krohne.mhs.compuserve.com
board.
Thank you for help.
Adam
> To: Nguyen, Adam D
> Play
> > Manager.
> Hi Adam,
> called
> for
> the
> AT-GPIB/TNT.
> Hope this helps.
> Bye,
> Ulrik Schoth
> Project manager R&D
I just got a National Instruments PCI-6031E board; this is Plug and Play
Manager.
I would appreciate if you will help me to solve this problem.
Thanh you;
Adam D. Nguyen
adam.d.nguyen@boeing.com
Subject: Re: SICL lockup in NT4?
To: stanb@hpnmrsb2.sr.hp.com (Stan Bischof)
Date: Tue, 4 Nov 97 7:36:58 MST
> Will experiment some more.
Stay in touch, Stan. We get odd reports like this every now and then and
they're the very devil to figure out.
> Stan
