Members of the VRf,
Along the same lines as Mr. Timian's question: is this problem going to be
addressed, and, if so, when? I am asking because the whole question of CPU
usage came from work I am doing for a customer at one of the National
Laboratories, and he has a real dislike for anything that looks like a CPU
hog. As a check, we fired up LabVIEW 5 (I hope that that isn't a forbidden
word in this forum) and set up the same small program - a simple counting
loop with a delay timer in it. When we ran this virtual instrument we found
that during the delay period, CPU usage was less then 1% as opposed to 100%
for HP-VEE 5.
My customer is now looking through his National Instruments catalogs, if you
catch my drift. Any insight into HP's plans would be most helpful.
Frank Carey
Computer Application Scientist
Schafer Corporation
303 Lindbergh Avenue
Livermore, CA 94550
fcarey@schafercorp.com <mailto:fcarey@schafercorp.com>
(925) 447-0555 x212 (925) 447-0579 /fax
www.schafercorp.com <http://www.schafercorp.com>
Sent: Friday, July 03, 1998 7:34 AM
To: HPVXD
Subject: VRf-CPU Usage Question
Greg,
Is there anything we can do as users to "prod" them along also.
Steve
> Sir:
> This is a very well known problem with VEE. The ON CYCLE and WAIT objects
> should properly release control to the OS until they time out, but instead
> they just sit there in tight timing loops.
> This has been a complaint for a long time and it's becoming increasingly a
> nuisance. The lab's normally responsive to high-profile problems, but for
> some reason this one never seems to make it to the top of the queue.
> I'll have to prod them again and raise the priority.
> [<>] regards -- gvgoebel
for HP-VEE 5.
Frank Carey
Schafer Corporation
Livermore, CA 94550
To: HPVXD
Greg,
Steve
> Sir:
