Dear Ralf,
why do you use an ActiveX element? If you are take a normal listbox the box
will have the focus and you can select everything with the arrow keys.
I myself do not believe that it would be very useful to make parts of a
window with an ActiveX-object. If it is possible to handle everything in the
ActiveX-object it is ok. But you have always the problem which application
has the right to draw a window.
I am sorry, but something happend with my email. It came back without text.
So I am sending it again.
Best regards
B. Aufenanger
Somatec B. Aufenanger & M. Bernhardt
Jagdweg 7a
D-82041 Deisenhofen
Telefon : (089) 613 984 91
Fax. : (089) 613 981 23
Email : Aufenanger@somatec.de <mailto:Aufenanger@somatec.de>
homepage : http://www.somatec.com <http://www.somatec.com>
<mailto:ralf.eichele@smart-gmbh.de> [mailto:ralf.eichele@smart-gmbh.de]
<mailto:[mailto:ralf.eichele@smart-gmbh.de]>
Sent: Wednesday, January 13, 1999 7:24 AM
To: 'hpvxd_xc@hpislsup.lvld.hp.com'
Subject: VRF: How to set focus to an ActiveX Modul
<< File: ActiveXMenue.vee >> SMART Electronic Development GmbH -
Germany
Von: Ralf Eichele@SMART <mailto:Eichele@SMART> GMBH am 13.01.99
09:24
An: hpvxd_xc@hpislsup.lvld.hp.com
<mailto:hpvxd_xc@hpislsup.lvld.hp.com>
Kopie:
Thema: VRF: How to set focus to an ActiveX Modul
Hello everybody,
I am thinking about a realisation of an PanelDriver with ActiveX,
but I
have the problem, that my ActiveX Modul (ListView) don't get the
focus when
I start a UserFunction where the ActiveX Control is integrated. But
I need
the focus, because I want to control everything only via the
keyboard. If
the ActiveX control has the focus (e.g click with the mouse on the
ListView
object) everything works fine via the keyboard.
Does anybody know how to set the focus for the ActiveX Modul? Or
does
anybody know something about a similar ActiveX modul, where it is
possible
to set the focus?
(See attached file: ActiveXMenue.vee)
Greetings
Ralf Eichele
Best regards
B. Aufenanger
Jagdweg 7a
D-82041 Deisenhofen
Germany
09:24
Kopie:
Hello everybody,
but I
focus when
I need
keyboard. If
ListView
does
possible
to set the focus?
Greetings
Ralf Eichele
