At 16:17 21/01/99 -0700, you wrote:
> VEE 5.01
> IOLIB G.02.01
> 54600 scope
> Win98 (operates same as Win95)
> E2050 LAN-HPIB
>-- performing a "*RST;*CLS" gives an EOI flag on a bus analyzer connected
>to the scope and LAN-HPIB box when EOI is set in VEE Instrument Manager
>configuration for the scope. Eliminate that setting and the EOI goes away.
>Add it again and it comes back.
>No problem found. Were you using a bus analyzer to detect EOI?
I wasn't.
But,
I'm afraid that what your solution does not solve the problem."*RST;*CLS"
are SCPI commands and my device does not conform to this standard. Moreover,
if we perform a clear, the device goes into a initialization process, which
is not acceptable.
But the remaining question is why the EOI works using the PCI card and it
does not work with the E2050A.
Regards.
| Juan Vera |
| E-mail: jvera@mdr.indra-espacio.es |
| Phone: 34-913 963 986 |
| Fax: 34-913 963 912 |
| Earth Stations Department |
| INDRA ESPACIO S.A. |
| Mar Egeo 4, Pol. Ind. 1 |
| San Fernando de Henares |
| 28850 MADRID |
| SPAIN |
> VEE 5.01
> IOLIB G.02.01
> 54600 scope
> E2050 LAN-HPIB
I wasn't.
But,
is not acceptable.
Regards.
| Juan Vera |
| 28850 MADRID |
| SPAIN |
To: "'VRf'" <hpvxd_xc@hpislsup.lvld.hp.com>
Subject: VRf- Data file directories
Date sent: Wed, 20 Jan 1999 11:16:31 -0500
> Hello VEE Group,
> I am having trouble with VEE looking for data files in the default files
> location. Using a file i/o object, I specify the file name without any path
> information. I expect VEE to look in the current working directory for the
> file. Some times it does and sometimes it does not. Does anyone know why
> this happens? One solution would be to get the current working directory,
> but I can not figure out how to do this.
> Any help is appreciated.
> Jeff Bruce
> Sr. Test Engineer
> Boston Acoustics
> 978-538-5000 x2908
> jeff.bruce@bostonacoustics.com
Try this peace of code:
Georg Nied
Software Development
51149 Koeln
Germany
gn-software@iname.com
ICQ 23490440
