I parsed the vee.io file for installed instruments. This makes my
program dynamic on what is set up in vee though, not what is connected
to the bus.
(0 0)
---------------(_)--(_)--(_)---------------
Dave Paslay Coin Acceptors
Engineer 300
Hunter Ave.
Automated Test Systems St. Louis, MO 63124
dpaslay@coinco.com
> -----Original Message-----
> From: Kok A. [SMTP:A.Kok@gasunie.nl]
> Sent: Friday, January 15, 1999 4:10 AM
> To: 'hpvxd_xc@hpislsup.lvld.hp.com'
> Subject: Scanning HPIB bus for instruments.
> Importance: High
> Hello all,
> I want to scan de HP-IB-bus for connected instruments. At this moment
> i use the bus time-out to see if there is an instrument connected at
> that adres.
> This take a long time to complete when you check al teh possible
> adresses.
> Doe anyone have a better and faster idea?
> Albert Kok
> Gasunie Rsearch
to the bus.
(0 0)
Engineer 300
Hunter Ave.
dpaslay@coinco.com
> Importance: High
> Hello all,
> that adres.
> adresses.
> Albert Kok
> Gasunie Rsearch
What I normally do is go in a loop performing a serial poll and look for the
sweep to be complete before trying to read data. For HP spectrum analyzers
this is usually on bit 2. Don't read it too fast or it will slow down the
analyzer. Put a 100 msec delay in the loop. Also it is best to first read
the sweep time from the analyzer so you can set a timeout in the loop.
Tom Sanders
Sent: Thursday, January 14, 1999 6:02 AM
To: hpvxd_xc@hpislsup.lvld.hp.com
Subject: vrf - trace data from spectrum analyzer
Hello All,
Now, I use HP VEE 5.01 on the Microsoft Windows 95 platform, and test for
data acquisition using spectrum Analyzer. I want to receive trace data
continuously from SA but the trace data are suddenly stop after few minites.
First, the SA occurs error message with command error, but the command is
right. And then VEE gives error message with time out error. I don't know
why the problem occur.
I attach the sample file. Please find any wrong algorithm.
I appreciate any help.
Best Regards,
Cris,
Systems Engineer
