Greg and list,
Thanks - I see what the difference is now.
I was using an old function library (VEE3) in a new
program (VEE5) and had not resaved the library in
VEE5 format.
So the solution is to be sure to resave and re-test
old VEE3 libraries before using them in VEE5.
Thanks again,
Peter Fender
Raytheon Systems Co.
St. Petersburg, FL
Date: 1/15/99 11:47 AM
To: Fender, Peter
Peter Fender wrote:
> Hello all,
> Is this a bug in VEE, or can someone explain what is
> wrong with this program ?
Sir:
Not a bug as such, though it was a bug not to document it more prominently.
Due to changes made in VEE for ActiveX, this operation no longer converts
automatically from integer to real in Standard Mode. You have to specify
this as a real operation.
"There's no such thing as a *little* change."
[<>] regards -- gvg
Greg Goebel ftp://fcext3.external.hp.com/dist/mxd/index.html
HP MXD Marketing http://hpislsup.lvld.hp.com (HP only)
pctm@lvld.hp.com http://www.geocities.com/CapeCanaveral/Launchpad/6000
VEE5 format.
Thanks again,
Peter Fender
St. Petersburg, FL
To: Fender, Peter
Peter Fender wrote:
> Hello all,
Sir:
[<>] regards -- gvg
> Hello all,
Sir:
[<>] regards -- gvg
