VRF- Thanks, and another question
Question asked by VRFuser on Jan 26, 1999
Hi Josh -
> setting them up as panels. I'm wondering if it's possible to remove the
> title bar, so all that is showing is just the graphic itself. I've tried
> going under preferences and unclicking the "Show Title Bar", but it
> doesn't seem to work. Am I going about this the right way, or is there a
Actually, you did the right thing in the wrong place. Go to the panel view
of your function (or object) and right click on the title bar.. select
properties. Change "Show title bar" there and you'll get the desired result.
Take a loot at all the properties here. Most of these properties control how
things look when you see the panel view, not the detail view.
Shawn Fessenden
Mgr., Technical Support
Oswego Software, Inc.
mailto:shawn@oswegosw.com
http://www.oswegosw.com
