vrf Excel and General VB question: CreateObject
Question asked by VRFuser on Oct 17, 1999
Dear Colleagues,
I am having difficulty understanding how to properly use the Createobjet()
function with excel.  I understand in the examples that to create a Excel
worksheet I need to use the following command
CreateObject("Excel.Sheet");
My misunderstanding is how to interpret this in the Visual Basic Object
browser.  When I look for a class "Sheet" I can not find one.  I can only
find "SheetS" or "Worksheet".
I was trying to use the following code to make a workbook and set up the
sheets as follows
Set myWB = CreateObject("Excel.workbook");
myWB.sheets("sheet1").select;
myWB.sheets("sheet1").name("frequency sweep 1");
....the rest is just adding sheets and renaming them.
I get an error that the object is not the right type
myWB is defined as a Library: Excel Class: Workbook.
Any thoughts on how to CreateObjects by understanding the Class structure?
Sincerely,
G. Matthew Kennedy
Field Engineer
Doble Engineering Company
Phone: 617-926-4900 x361
Fax: 617-926-0528
email: gmkennedy@doble.com
to "vrf-request@lvld.hp.com".
