I am using IC-CAP 2008 640.200.
I tried to simulate the following example model file provided with IC-CAP
/export/tools/ICCAP640r200_linux/examples/model_files/diode/pn_diode.mdl
pn_diode.mdl uses spice2 as the default simulator.
After extraction and simulation the obtained idvd and cjd plots are satisfactory.
Now I changed the simulator to HSPICE and tried to re-simulate.
The idvd plot is satisfactory but the Cjd curve is abnormal.
Why is it so? As HSPICE also supports the D model used by spice2 I donot find any reason why the cap plot should be abnormal.
Could anyone check it out and help me out of this? I am using HSPICE 2004.03-sp1.
Thanks
Bharat
Thanks
Bharat
