AW: vrf Short beep-message with "no" h file
Question asked by a.kieser on May 3, 2000
how can I delete this file? Is there an elegant solution for NT4 and for Win
95/98?
MfG
Axel Kieser
> -----Ursprngliche Nachricht-----
> Von:     Georg Nied [SMTP:gn-software@gmx.de]
> Gesendet am:     Mittwoch, 3. Mai 2000 22:17
> An:     'Vee Reflector'
> Betreff:     RE: vrf Short beep-message with "no" h file
> My dear colegues..
> you have to mark the 'clear file at prerun and open' checkbox! Otherwise
> the
> beep-function is imported once more,
> each time! Even better: delete the self-created h-file after importing of
> the library!
>         Georg Nied
>    Software-Development
> Hansestr.7 - 51149 Cologne
>         Germany
>  Mail: gn-software@gmx.de
> > -----Original Message-----
> > From: owner-vrf@hplvlrx.lvld.hp.com
> > [mailto:owner-vrf@hplvlrx.lvld.hp.com]On Behalf Of Cornelius,
> > Hal (RPI)
> > Sent: Wednesday, May 03, 2000 3:11 PM
> > To: Vee Reflector
> > Subject: RE: vrf Short beep-message with "no" h file
> > I also tried the beep program without the h-file, in the development
> > environment.  The explorer indicates that another beep
> > function is being
> > added every time the beep function is called.  This does not
> > occur when the
> > h-file is normally included.
> > Also, the frequency and duration inputs don't seem to change anything.
> > Hal Cornelius
> > Research Planning Inc.
> > China Lake, Ca.
> > 760/939-9008
> > > From:     Rissone Ruggero [SMTP:Ruggero.Rissone@cselt.it]
> > > Sent:     Wednesday, May 03, 2000 12:40 AM
> > > To:     vrf@lvld.hp.com; 'Allan Strmbert (ERA)'
> > > Importance:     High
> > > Hi Allan,
> > > This morning I've tried your Prog....
> > > It works but at the end of the program, an error occurs.
> > > Error Number 739
> > > "Stack Pointer Corrupted after return from compiled function <Beep>"
> > > I'm using Win NT 4.0 SP6a"
> > > Best Regards
> > > Ruggero Rissone
> > > Torino- ITALY
> > > > From:      Allan Strmbert
> > (ERA)[SMTP:Allan.Strombert@era.ericsson.se]
> > > > Sent:      marted 2 maggio 2000 11:42
> > > > To:      vrf@lvld.hp.com
> > > > <<File: beep2.vee>>
> > > > Hi Axel,
> > > > Just a hint, to let the program create the h-file within
> > its self is a
> > > > convenient way.
> > > > You do not need to handle the extra h-file and it is
> > ready to start
> > > right
> > > > out of the bed.
> > > > I have had used it before in the equal nice function sleep.vee.
> > > > The write / read to file will of coarse make it a bit slower.
> > > > Thank you B. Aufenanger for an other handy function.
> > > > Regards,
> > > > Allan
> > > > email allan.strombert@era.ericsson.se
> > > > Dear Axel,
> > > > I don't know why the beep in VEE doesn't work. But it is
> > easy to use the
> > > > beep from the kernel DLL and this works fine. I will
> > include an example.
> > > > Best regards
> > > > B. Aufenanger
> > > > Somatec B. Aufenanger & M. Bernhardt
> > > > Jagdweg 7a
> > > > D-82041 Deisenhofen
> > > > Telefon          : (089) 613 984 91
> > > > Fax.               : (089) 613 981 23
> > > > Email             : Aufenanger@somatec.de
> > > > homepage     : http://www.somatec.com
> > > > Behalf Of a.kieser@francotyp.com
> > > > Sent: Friday, April 28, 2000 1:08 PM
> > > > To: vrf@lvld.hp.com
> > > > Subject: vrf Short beep-message
> > > > Hi there,
> > > > for a counter I want to have a short beep message for every count.
> > > > Unfortunately the HP Vee 5 command 'beep' does not work
> > as it should, it
> > > > always plays the standard .wav -file of Windows. So what
> > can I do to get
> > > a
> > > > very short acoustic message for every count?
> > > > Thanks for answers in advance
> > > > Axel Kieser
> > > > This email message has been swept by MIMEsweeper for the
> > presence of
> > > > computer viruses.
> > > > Francotyp-Postalia AG & Co.
> > > > This is the "vrf" maillist, managed by Majordomo.  To
> > send messages to
> > > > this maillist, just email to "vrf@lvld.hp.com".  Subscriptions and
> > > > unsubscriptions are done through the address
> > "vrf-request@lvld.hp.com".
> > > > If you need details, just send a message containing the
> > text "help"
> > > > to "vrf-request@lvld.hp.com".
> > > This is the "vrf" maillist, managed by Majordomo.  To send
> > messages to
> > > If you need details, just send a message containing the text "help"
> > This is the "vrf" maillist, managed by Majordomo.  To send messages to
> unsubscriptions are done through the address "vrf-request@lvld.hp.com".
This email message has been swept by MIMEsweeper for the presence of
computer viruses.
