vrf Timer
Question asked by VRFuser on May 24, 2000
> From: c [mailto:carsten75@sol.dk]
> Sent: Wednesday, May 24, 2000 2:40 PM
> To: vrf@hplvlrx.lvld.hp.com
> Subject: vrf Timer
> Im using VEE 5.01 on a win 95 mashine, but a have some
> difficulty programming a "Timer" function.
> At Timer that starts on at specific signal and then runs for
> at given time and
> at the end of that periode activates another signal.
> I have tried with different buildin functions nothind seems
> working, either it
> starts at once or it delays the whole program.
> Any solution would be appreciated
> Carsten Carbel
> Carbel@nork.auc.dk
Hello Carsten,
VEE's "Timer" object (Device pulldown menu - Timer) outputs the
difference in seconds between the activation times of the top and
bottom data input pins.  Use a Timer to measure how much time passes
between two events, such as objects operating.
I think you are asking for VEE's "Delay" object
(Flow pulldown menu - Delay) which waits a specified period of
time before activating its Done data output terminal.
Use Delay to delay execution of a thread segment for a specified
number of seconds.
I attach a simple example VEE 5.01 program.
Hope this helps!
| Ted Cline
| PC Test & Measurement Support
| Measurement Products Unit (MPU)
| Agilent Technologies
| CU-326, 815 14th Street SW, P.O. Box 301, Loveland, CO 80537  USA
| 800-452-4844  Customer Support (United States)
| 877-894-4414  Customer Support (Canada)
| 970-679-5260  FAX
| ted_cline@agilent.com
| pctm@lvld.hp.com
| http://ftp.agilent.com/pub/mpusup/index.html  Postsales Support
VEE:
  http://www.agilent.com/find/vee
I/O Libraries:
  http://www.agilent.com/find/iolib
Instrument Drivers:
  http://www.agilent.com/find/inst_drivers
