vrf Data container
Question asked by VRFuser on May 25, 2000
You need a From String object set to Token Format, Include Characters
"0123456789". This ignores anything in your input string other than digits.
This outputs text, so if you want numeric data, use the asReal function. See
the changes in your attached example.
Bill Ossmann
bill_ossmann@agilent.com
Agilent Technologies
Imaging Systems Division
From: Guy Bonneville [mailto:guybonne@nortelnetworks.com]
Sent: Friday, May 26, 2000 10:07 AM
To: 'vrf@lvld.hp.com'
Subject: vrf Data container
Hi everybody,
I was wondering if anybody had a solution to this problem.
I want to be able to search a database using the filename which is named
after a transistor's bias point, ex: v20b120.(voltage 2.0V, current 120uA).
To do that I need to  extract the values from the the filename.
Any ideas?
Thanks, Guy <<Datacontain.vee>>
