Hi, everyone,
I am trying to thicken the sheet to 0.8 um thickness.
Error msg appeared "feature #18 failed, offset null or will make body too thin or inside out"
however, when I changed the thicken distance to 2 um, this error disappeared. While 1.9 um still does not work.
At first, I doubt whether this is due to the sheet geometry being imported from dxf file.
Then, I imported another dxf file and found 0.8 um thickness thickening does work.
Anyone has any ideas?
Thanks
Thanks
