Hi, all,
I need to simulate the geometry as shown in the following figure.
Is it possible to draw this ribbon like geometry?
Thank you very much
Yours,
Yiliu
Thank you very much
Yours,
Yiliu
1) draw a cylinder, (cross section (X-Z) being a circle, extrude in Y direction)
2) cut the cylinder two heads parallelly, with the cut NOT vertical to Y direction ( X-Z cross section changed to ellipse)
3) cut a small portion of the bottom (X-Z cross section ellipse will be partly curve of ellipse + one line connecting the two heads of the curve)
4) make a sheet body of the geometry round face
5) Connect two sides of the sheet completed in step 4 to the footprint with sheets
thank you all!
