Unfortunately, we have some low resolution data of IDvsVD that we must extract a derivative from. What math technique would you recommend that would allow a possible derivative?
Also, if your data that you want to apply the math/derivative function on comes from data external to IC-CAP, you will want to pay attention to the following support note:
"ICCap.464 : IC-CAP "derivative()" PEL Function Does Not Work On Data Referenced Or Imported From Outside Defined Iccap Setup Unless You Define Appropriate Input/Outputs To Match Size/Dimension Of "derivative" Function's Input Data ...":
"how to calculate deriviative..":
https://edasupportweb.soco.agilent.com/portal/page?_pageid=36,39953&_dad=portal&_schema=PORTAL&itemid=42153&ref=related
https://edasupportweb.soco.agilent.com/portal/page?_pageid=36,40628&_dad=portal&_schema=PORTAL&id=155866&ref=related
Finally, if you have more direct questions/comments, please feel free to send your working IC-CAP model to EEsof technical support team. Â
