building a record
Question asked by VRFuser on Aug 13, 1999
I am using a sequencer to sequence a series of tests. When I am done I
build a record.
Input to the record is:
timestamp
serial no
operator no
job no
and from the sequencer - test results with pass/fail= 1/0.
Then I do a 'tofile', then 'fromfile'.
When I open the file in wordpad I get alot of information that is hard to
read.
Is there a way to organize the data?
i.e, add a space between each test?
create name fields and put the data under those fields?
Also, can I make it say "pass/fail" instead of 1/0 in the record coming
from the sequencer?
any help is appreciated
thanks
