AW: Access to dynamically changing variable names
Question asked by VRFuser on Oct 13, 1999
Hi
I just open the XX.vee file with Notepad or Word and then print it
Heiko Degenhardt wrote:
> "Kennedy, G. Matthew" wrote:
> > Is there a method that you can print your program code to a file over a
> > printer.
> The following way works for me (Win98, VEE 5.01):
> Install a printer driver for a PostScript printer (e.g. HP
> LaserJet4050)
> and connect it to FILE (in Win9x: Start -> Setup -> printer, than
> "Details").
> Then use that printer to print your program.
> You can see the result with a postscript viewer, e.g. ghostview.
> With kind regards.
> Heiko.
> This is the "vrf" maillist, managed by Majordomo.  To send messages to
> this maillist, just email to "vrf@lvld.hp.com".  Subscriptions and
> unsubscriptions are done through the address "vrf-request@lvld.hp.com".
> to "vrf-request@lvld.hp.com".
Regards
Michael Clavien
INDCONTROL Pty Ltd < POWER ELECTRONICS and CONTROLS >
           294 Norton St Leichhardt 2040 Australia
