Different resolutions causing problems
Question asked by aufenanger on Jul 1, 1999
Hi;
     I'm using VEE to take measurements and put the results into EXCEL.  EXCEL
then generates a chart which I want to export to a graphic and load into the
VEE panel for web-monitoring purposes.  I found that the following Visual
Basic for Applications command will create a GIF file:
ActiveChart.Export("CurrentChart.gif")
     However, the GIF file is unreadable in VEE.  It causes an unknown format
error with a message: "Expected",", got "!".  Has anyone else seen this
before?  Does anyone know if EXCEL can be made to export to a BMP?
Curtis
