Does anyone know how to left justify an alphanumeric display?
Question asked by VRFuser on Jun 17, 1999
Brian,
You could use a to string to format your output before sending the data to a
display.
                                             Todd
Sent:     Friday, June 18, 1999 10:20 AM
To:     Brian Kocinski; hpvxd_xc@hpislsup.lvld.hp.com
Subject:     RE: Does anyone know how to left justify an alphanumeric
display?
Brian,
A logging Alphanumeric will left justify the data for either scalars or
arrays.
Tom Sanders
Symtx Systems Engineering Manager
19200 Stevens Creek Blvd., Suite 120
Cupertino, CA  95014
(408) 343-3610
(408) 343-3616 (fax)
http://www.symtx.com
From: Brian Kocinski [mailto:briank@alto-shaam.com]
Sent: Friday, June 18, 1999 6:23 AM
To: hpvxd_xc@hpislsup.lvld.hp.com
Subject: VRF: Does anyone know how to left justify an alphanumeric
display?
I'm running VEE 5.01 and am trying to set up a list of  items that are
obtained  from various user inputs throughout the program.  I read the
inputs into individual global variables.  The variables are then read and
displayed to separate alpha numeric displays on a main panel.  It would be
cleaner and more readable if I could left justify the data seeing how the
strings are not all the same size.  I made all of the displays longer enough
so that the longest string would fit, but the shorter strings are centered
and the data doesn't line up.  Does anyone know where in the software that
this option might be available or some alternative method?
Sincerely,
Brian C. Kocinski
Test Engineer
Alto-Shaam, Inc.
(414) 253-6472
