AW: Dynamically create records?
Question asked by bernhardt on Jul 26, 1999
Hi Martin,
the only way I know is to write an ASCII-File to the harddisk, which
contains the structure of a dataset containing your desired record
structure. You can read out one record from the created dataset and you have
your record.
M. Bernhardt
Somatec B. Aufenanger & M. Bernhardt
Jagdweg 7a
D-82041 Deisenhofen
Telefon       : (089) 613 984 94
Fax           : (089) 613 981 23
Email           : Bernhardt@somatec.de
homepage     : http://www.somatec.com
> -----Ursprngliche Nachricht-----
> Von: Martin,Roger [mailto:rmartin@granville.com]
> Gesendet am: Montag, 26. Juli 1999 22:31
> An: HP VEE Reflector (E-mail)
> Cc: George Tyrrell (E-mail); George Tyrrell VM (E-mail)
> Betreff:  Dynamically create records?
> Hi all,
> I would like to programmatically build a record that allows
> the number of
> fields and the field names to change depending on the
> structure of an Access
> database I am talking to via ActiveX Automation (ADO).
> I can get this information from Access but is it possible to
> dynamically
> define the structure of a record (number of fields and name
> of each field)?
> Thanks,
> Roger Martin
> Manufacturing Engineer
> email: rmartin@granville.com
> phone: 303-998-4045
> fax: 303-443-2546
> HELIX TECHNOLOGY CORP.
> Granville-Phillips
> Boulder, CO USA
