vrf Serial Port
Question asked by aufenanger on Dec 19, 1999
So I would try to set "RTS" and to reset "DTR" in some kind of initial
routine and make the communication further on without handshake. This should
be no problem.
Best regards
Barbara
Somatec B. Aufenanger & M. Bernhardt
Jagdweg 7a
D-82041 Deisenhofen
Telefon          : (089) 613 984 91
Fax.               : (089) 613 981 23
Email             : Aufenanger@somatec.de
homepage     : http://www.somatec.com
From:      owner-vrf@hplvlrx.lvld.hp.com [mailto:owner-vrf@hplvlrx.lvld.hp.com]
On Behalf Of Ekkehard Werner
Sent:     Friday, December 17, 1999 2:22 PM
To:     VEE Usergroup (E-Mail)
Subject:     Re: vrf Serial Port
I don't want to use the RTS and DTR pins for handshake but as power supply
of
the device connected to COM2 (i.e. a thermometer, P505, Dostmann electronic
GmbH).
So RTS must be at "high" and DTR at "low" all the time.
Regards
Ekkehard Werner
B Aufenanger schrieb:
> Yes, you can write IOCONTROL and set every Handshake yourself.
> Sent:   Wednesday, December 15, 1999 2:21 PM
> To:     VRf mailing list
> Subject:        vrf Serial Port
> Is it possible to set the pins RTS and DTR of the serial COM2 port to
> high and low respectively while writing and reading COM2 with an HP
> Vee-program?
> Regards
> Ekkehard Werner
to "vrf-request@lvld.hp.com".
